Sedanman
67-9 Valiant specialist
I have a complete gone through and painted dual diaphram power disc brake booster set up for 67-72 a bodies. I was going to use on my car but decided to stay manual disc brake and use the money for other needed parts. This booster was factory on all 67-72 a,b & c bodies with power disc brakes but they didn't use the bracketry. It includes all brackets,reman 15/16 pb master,rubber hose,intake fitting,new firewall gasket set,new fine lines brake lines and some extra booster valves. The master push rod will have to be adjusted when you install it for the right amount of play $200 + ship
The single diaphram boosters are for drum brake cars
