67-9 2dr sedan door striker repair
Sedanman
67-9 Valiant specialist
chicago Il
I have a 67 valiant & due to both doors having bad hinges for a long time it has cracked the sheet metal around the striker. I see they sell the panels for ht but haven't seen anything for sedans. What is the best cost effective way to repair this? I already have new door hinges (not installed yet) and would like to address this issue before I have the jambs painted. I am assuming the metal is too thin to weld & grind on. Thanks in advance & pics are helpful.
I dont know much about metal repair but what about going in behind the striker and beefing it up?From the pics it doesn't look to bad.
1 has multiple cracks & the other seems to be cracking in a circle around the striker & I'm sure it a matter of time before it cracks off. The striker needs to be able to move around when adjusting the doors & I think any welds may get in the way of that.
You are lucky. The previous owner of my '68 welded the post to the jamb! I've got to grind away the circumferential welds and put in a replacement kit.
My car is a 71 and had the same problem. With sagging doors and thin metal round the striker it's gonna happen. I had a 73 parts car and the jambs were perfect. They had about a 4" sq 1/4 backing plate. So I drilled out the striker and added it to the 71. Hope this gives you an idea. So parts car or a kit, it's your choice. Hope this helps.
this is what i did to reinforce my 69. I copied what Chrysler did on later a bodies.I cut a plate out 11 or 12 gauge steel big enough to weld the nut carrier to .then plug welded the whole unit to the back side of the door pillar.
