[Found!] 67 A Body 4 speed Hurst shifter
Ozzy
Harborcreek, PA
Rating - 0%
0   0   0
Looking for a used, but working shifter mechanism. Reverse gear finger has 2336 printed on it, 1-2 finger has 2130, and 3-4 finger has 2359.
Does it look like this? I can't go grab it right now to check the numbers
This one's complete and ready to go! It's got the right numbers but you confirm the fitment. If your interested, start a conversation. Thanks
67 shifter was an Inland shifter. You can use the 64-65 as above or 68-up. Linkage is all the same. Use the 67 up mounting block for a little better alignment.
agreed every 67 ive seen is an Inland shifter originally
