[WANTED] 67 barracuda k frame
Unless you are trying to keep it OE look for a 68-69 SB V8 K member, the 68-69 idler arm is stronger and cheaper
I agree, even if you find a 67 frame good chance the idler mounting will be wallered out and be useless. Locate a 68-72, 99.99% direct change over, just need the 68-72 idler.
I would add, unless you need this car to pass the scrutiny of a judge crawling under the car pass on the 67, IF you can find a 67 idler it will not be cheap.
Alan
You can add the brace for a 68-72 idler arm to your k-member. I cut them off off k-members and weld them on in the car if you need to do that. Easy to do.
I think he is trying to stay all 67, and I have a couple 67 K frames, one still in the car and a /6 one on the shelf.
