67 barracuda seat belts needed
bumnround
My car came with one chevy seatbelt on the driver side,thats it. So I am looking for a complete set of black belts for a bench seat application. What other cars would be the same as 67 barracuda. Any pic's would be great. Thanks in advance. Greg p.s. also need all armrests and bases for same car thanks again
I saw a pair of black 67 elbow pads on ebay a few days ago. 60 dollars I think.
Unless you are building a concours correct car, there are faults with the 67 belts you should be aware of and options to consider.
The 67 buckets are huge chrome belly burners. The male tounge goes to the door and scars the door bottom. The retracter is actually a spring loaded roller that attaches to the center of the belt. It can scar the door too.
68 had a retractor that stayed inside a housing ( that thing is a pain to reload ) and the male tounge was still on that side.
There are bolt holes hidden behind your headlinner for shoulder belts so aftermarket 3 point belts can be installed.
