67 cuda notch quarter glass removal
bumnround
I can't get the glass out. Tried every which way, no come out?? help?
Did you remove the upper ( steel ) door panel ? Lean the glass out at the roof as if rolling it up too far. Thats the best I can describe it.
Some info from factory service manuals is available in related threads.
I removed them with the upper moldings still in place. Like RedFish says, remove the upper steel panel and the door jamb seal. Take all the removable hardware off the window and take it outside of the roof rail and a bit forward using the void the jamb seal covers.
I got them out. I was trying to take them out through the outside of the car, but they came out on the inside toward the headliner. Thanks for the support.
