67 Dart rear quater window roller
67DDDart
Taxachusetts
Do I replace this unit as an assembly or just replace the roller?
Might depend on how bad all the rollers are. That white one I believe is replaceable through RT Specialties, not so sure about the two that ride inside the metal part.
I took all mine and drilled out the rivets and cleaned them up and reriveted them and they work like a charm.
What's not shown in the photo above is the chunk missing from the roller on the other side. I didn't see any rollers that look like this one at RT Specialties (it has a ball on the end). Would I press off the roller and press on the new one?
I think that's what you're supposed to do. They have one roller that says it's a press on, and I was pretty sure it was that one since I ordered it by mistake. You could call them and double check.
