67 dart wing window removal
electrocuda64
Member
we are trying to replace the wing window on our 67 dart. Should we replace just the window or the whole track and window? If so how do we replace this? Thanks
if you need to change just the glass then you have to remove the screw that is below the top of the door on the bottom of the window. The chrome piece that holds the bottom of the glass has a stem held by this screw.
I changed the glass in mine but the frame was off the car. Don't know how much room there is to work inside the door to remove this screw.
