[Found!] 1967 Dart GT hardtop wing window needed Passenger side
The 67 uses a Phillips screw to clamp the assy to the door.(Screw visible when installed.)
68 up uses different attachment method, (screw is recessed and a plastic cap covers it) my recollection (might be wrong,)is that the innards at that attachment is different.
Where are you located? I've got some spare assemblies, but I have to set aside the ones for our cars.
Still have glass only if that helps
I have a friend coming to the mopar event from clear lake if that helps
