67 fold down rear seat diagram??
dustya_383
san Jose Ca
Any one know where to find a diagram for the fold down rear seat on the second gen barracuda? Or anyone know how to tear one down? Latch is not working and when released manually seat only folds down 1/2 way. Any info would help thank you.
Give me a minute. It's in here. 67 Plymouth supplement down the page
MyMopar - Mopar Forums & Information - Service Manuals
Great thank you.
I got access to the parts inside. appears something was binding I’m assuming the “bearing rides in the bracket with the lever“ ( I’m using terms from the diagram) now mine doesn’t have a “nut” just the clip in photo I took does that go on other side of the bracket ? . Does anyone know if these bushings are re popped? Thanks
Just going on what I see in your photos
Slide the metal part with the plastic on it (lever and bearing) into the bracket. Insert the link into the lever. Looks like there is a setscrew you might have to loosen.
That nut is probably the clip. From what I see the bearing and lever slide up into the bracket. Then the link(round rod) goes into the round part on lever.
Like Dana said you could be missing a set screw.
