67 k frame
yes if you have a block that will accept factory big block mounts and have the mounts for that block. left side is special for a big 67 block k-member. if it was me i would look for a spool mount k-member for a small block 73-76. it will also have the better idler arm mount for the newer style. i saw the 67 big block k-member for sale. unless you have a factory big block 67 its a waist of money. everyone i knows gets rid of the 67 idler arm.
I'm not afraid of a 67 idler mount. As above there are a lot of scarce parts to install an original 383 in a 67-69 A-Body.
Yup, if the block doesn't have the left engine mount bosses/holes it's not gonna work.
And that one nub is shaved off the block to clear the steering box.
Sorry should I get a bb K Frame for my 67 barracuda
Original BB K frames are rare and expensive. Which K frame to use for a big block swap is an interesting and somewhat complicated subject. The DC K frame is a pretty good choice. Using a SB K frame with adapters is also a decent choice. You can also buy an aftermarket K frame. I'd recommend checking out some build threads before you make a decision.
