'67 Notch Radiator Question
MoparsRule
Indianapolis
I have a '67 Notch w/ a 440 and it has a 28"x23" (Part #2949033) radiator w/ electric fan in it currently that I would like to replace with an aluminum radiator/fan combo.
Anyone have any suggestions on a replacement?
Or, the other possibility is to pull the radiator & have it cleaned/repaired/brackets welded back on & reinstall it with a dual fan setup.
For that option, what fan setup would you recommend?
Thanks!
Ok, got the radiator back from the shop. For $65 they dipped it, pressure tested it, fixed two leaks, and painted it.
VERY happy with the outcome.
Now I need to find a Mopar shroud, or have one made... having ZERO luck finding a 28" shroud anywhere.
Any leads on one?
