67 Plymouth Barracuda rear window gasket
Or you can get a 68-69 gasket, and the 68-69 stainless and clips and use that. The chrome look plastic lock strip tends to get spotty, discolored, and yellow over time.
Check into Steele Rubber. They make the rubber gaskets and I'm pretty sure they make the '67 only gaskets.
For the plastic lockstrips, I'm not sure who makes it, but several venders have the stuff. You will have to gently heat and bend them for the curved sections.
Cross section and corner pieces looks like this
Hey thanks a lot for your help!
