67 Splash Guards? For 67 Barracuda Convertible
Winnipeg, Manitoba Canada
My 67 Barracuda was completed disassembled a year or 2 ago. My very knowledgeable mechanic that was doing most of the work passed away recently so I am trying to figure out where some things go. I have these 2 plastic things that each say LH and RH. They must go somewhere in the forward fender area or suspension just below the frame. I can’t figure out where they mount however.
Thanks for any help.
I don't know for sure but at front I believe riveted to frame rail. Chk frame rail for a hole pattern?
A factory parts manual is going to be your savior putting this together. That and fabo. Good luck!
They go under the frame rails right behind the strut rod, there should be holes present that match up with the holes in the shields...
Your welcome. If you don't have factory manuals(both a parts manual and service manual), go to Mymopar.com they are available free there.
BUT the 67 FSM doesn't have anything Barracuda specific. Dumbass mopar forgot and anything specific to cuda came out as a supplement separately. I have that digitally if you want to send me your email I can email to you? That is where you will find electrical schematics as well. You'll need those for sure.
My email: gerry.norberg@gmail.com
Thanks very much.
