I bought a used tank out of a '67 Barracuda last fall. Will it work in my '68?
I read somewhere that the '67 only uses 1 strap.
It would fit but as you noted the 67 only has 1 strap left to right. While the 68 up has 2 that run front to back.I bought a used tank out of a '67 Barracuda last fall. Will it work in my '68?
Yah but the tanks have grooves for front to back also.67 is left to right.
Aftermarket does. Not sure about O.E.Yah but the tanks have grooves for front to back also.
I converted my 67 to 68 and up straps. Used the parts off of that swinger I parted out. The only problem I see is where the straps hook to the crossmember holes I made are not reinforced, yet.Tabs where the strap bolts go are side to side. These cars werent built for universal tanks. I guess you could weld some in??
