So I'm making a plate to cover the AC hole in the firewall to mount a heat only box. I have all the holes and mounting points located BUT there are 4 small holes that I have no idea what they are for?
The holes are not evenly spaced around the center circle like the mounting holes are AND they are not equally spaced from each other?
Thoughts?
This is the heat only firewall as seen from the engine compartment
From DMT's website
Metal mounting ring (front)
Metal mounting ring (back) with OEM seal
T
Thoughts?
From DMT's website
T
