67 valiant headliner help
thanks Pauly I thought I remembered seeing that. dang if you were a little closer I would ask you to make a template of that on paper and send it to me. I wonder id the holes are needed?
the material is about 3/16", not sure what holds it on since i haven't taken mine off. if you look close you can see a rivet or something like that in the pics, if those aren't present on your car just use contact cement and be done with it.
