So I have a 68 cuda in restoration and I modified a 67 passenger fender for the passenger side.
Only mods was to weld up the emblem holes, bust off the 67 bezel retention plastic grommet and add a tang / screw clip for the 68 bezel front edge screw. No problem. 68 Bezel fits fine..with no headlight installed.
Well I get everything all painted up in the final color, headlight installed, and started installing the 68 grill and I have a problem, passenger side bezel won’t fit over the headlight. It seems the 67 headlight bucket is more offset towards the center of the car than the 68. Can’t be I say, never heard of such a thing.
So I measure the edge of the headlight to the fenders edge and its 3/8” of an inch more offset towards the center of the vehicle than the drivers side (which is a 68 and it fits perfectly).
I tried whacking the bracket with a sledge and a block of wood to bend the bracket over but no success. Looks like I’ll have to drill out the spot welds and move it over.
Am I smoking crack or is there a real difference between 67 and 68 fenders?
Thanks
Sean
Thanks
Sean
