when I purchased this 68 notchback project the passenger side quarter glass did not work. My father took it apart when I was at work and found a missing roller path and a broken roller assembly. I tracked down those pieces and today we went to put it back in. everything went together but when we roll the window up all the way the back does not roll up all the way and we cant adjust the regulator enough to right it. and when the window gets to within 2.5" of up, the bottom roller assembly pops out of its channel. When we measure all the way up on the driverside and crank the passenger side to same height, it is 3" from top.
after further inspection the passenger glass is one piece with the assembly, while the driver side the glass bolts onto the assembly. The rear channel that I replaced is at least an inch longer than the one on the driver side. So, do I have the wrong window for the passenger side? or is the window for a 68 but regulator for a different year???
WTH is going on here?? lol:banghead::banghead::banghead:
