[WANTED] 68 340 Timing chain cover
Found! 69 timing cover $70.00 shipped priced as due to portion of factory gasket still attached
just a little info
If you are doing a number correct 68 that is not the correct T cover, that one is a 69
just a little info
That is OK. It's not a matching numbers car. I was told that original motor froze years ago. I am building a 69 340 out of a gts. So i'm not concerned. I just needed a cover with the marks on the passenger side so i could see the marks.
