[WANTED] 68-69 A-Body K-frame
AintRich
New Member
wisconsin
Rating - 0%
0   0   0
Need a k-frame for a-body near SE WI. 68-69 Big Block would be preferred but I can cut the mounts and weld into a slant6 or small block piece. I'm not worried about a resto piece, but just want it in good shape.
I have a later 73-up ( spool mount ) k member that someone started on the dc-k big block conversion on if you are interested.
in the Waukesha area
Not quite what I was looking for, How much$$? I'm not that acquainted with the newer cars. Isn't the sway bar mount different?
sway bar mount is different, there is a write up on bigblockdart.com on how to do the conversion. if you are in the Waukesha area we could meet up and you can make an offer.
FYI...You can mount either style of sway bar on the DC spool mount K member. It all depends on the lower control arms your using. I have original K frames and DC frame. The spool mount has the advantage of not having rubber mount let go....no real torque strap required. The spool mounts a B body big block mounts.
