[SOLD] 68/69 Dart Ignition Key Light
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Here is an ignition key light that came out of a 69 Dart. It probably fits a 68 Dart and not sure about a 67 Dart. No idea if it will fit Barracuda’s of those years. IIRC there is a little opening in the dash for the light to shine at the key area. You will need the time delay relay installed and hooked up for this to work. It’s been a long time since I removed it, but IIRC the light is installed to the front of the ignition switch and everything secured with the bezel. $40 shipped from 22657.
I got all crazy for this because I want to add one of these to my 68 dart, but from what I was able to find the 68 dart and 69 darts had different diameter ignition switches. the 69 switch was bigger than the 68's. So this could potentially fit a 68, but I dont know how well
I can’t answer the question about different size ignition switches; I do know that this ignition key light fits an early A ignition switch as long as the ignition switch has the slot to position the light’s mounting bracket
"the 68 dart and 69 darts had different diameter ignition switches. the 69 switch was bigger than the 68's"
What carfreak6970 is true. I bought a 68 piece for my 69 Dart thinking it would be the same but indeed, the 68 had a smaller diameter hole.
