68 and 69 Dart grills
mrhinsjc
Active Member
San Juan Cap
Are 68 and 69 grills interchangeable? I have found repro 68 grills, but not 69. Is that correct, or did I just miss it?
Like said above, the headlight buckets are in different locations due to the welded headlight buckets on the fenders. You can make them work, but takes quite a bit of effort. No repro 69 grilles available. I have a dozen 69 grilles in Rockford, IL and there should be plenty to be found in your area...
Stating the obvious.
68 round marker lights.
69, rectangle marker lights.
