68 Barracuda fastback rear panel carpeting ???
RON REAGLE
BEAVER FALLS PA
I in the process of putting the carpeting on my rear cargo area side panels. I'm not sure how far to glue the carpet down against the area where you screw the panel to the body and then put the chrome strip on to cover the screws? Anybody have any detailed pictures of diagram of what's correct? My car had these panels painted and not carpeted so I have nothing to compare to. Thanks
Did you give more than 1 part number? Every time I open the link it skips to the second choice ? Thanks that's very helpful info
only one part # 665-2829 if you are worried about sound/rattle (I didnt notice any because they are tight) do what I did with other foam clips that you cant find//poke them through a peice of card board and hit them lightly with flex seal clear and let them dry before using them it also gives just enough grip to keep them in place
Slightly off-topic: my black carpet kit came with the side panel carpet pieces, but I have no intention of using them, or the hinge cover pieces or the console piece. So if anyone wants them for the cost of shipping, hit me up. Marked with red boxes in the pic.
I will ABSOLUTELY take them. I have speaker holes cut in mine but want a set that is stock uncut. Please pm me your info and I'll send you mine Thanks
Here's a couple shots of the rear panels after carpet installation. They already had a set of speaker holes cut in them I just added another set. I also put Hushmat on the backsides and silicon baffles around the speakers.
