68 Barracuda grilles
67GTConvert
Victoria B.C.
I have both grilles from a 68 Barracuda.
Driver side:
Surround is nice and straight except for a couple of real small dents on underside of top not easily seen.It has pitting but might polish out depending on material.
Headlight door is straight,no dents but has a fair bit of surface pitting.Inner headlight surround also has quite a bit of pitting.
Inner plastic grille is nice,chromed pot metal surround looks pretty good as well.Signal light has lots of light stress cracks but not broken.
Passenger side:
Surround is straight but has pitting and some 1-2" scratches that I'd guess could be polished out somewhat although I'm not an expert on that.Maybe someone on here knows more about it and can offer some insight.
Headlight door is similar condition but has small dent just below corner peak.Pot metal headlight surround has a few corrosion blemishes on inside edge but not too bad.
Inner plastic grille is very nice,no broken fins,paint still good.Metal surround looks usable,has some paint overspray but looks like it should clean up decently.
signal lens has several prominant stress cracks,housing and inside finish inside look ok though.
$75 each obo or might separate.Buyer pays for shipping.
Hello , do you know if these will fit my 69 Barracuda ? I know they would not be right for it but I don't have anything now .
I can't say for sure if they will or not,hopefully someone more knowlegeable than me on the subject can chime in.
They will fit a 69 if you install a 67 or 68 header panel. The peak in the 69 hood will look odd.
