Thanks for all of the input guys! Yeah I know the slant six is no powerhouse, but for now I am trying to just get it running for cheap and would only consider an engine swap after I've got all the body parts in hand. Also I think I can get this engine running for cheap.
When I tore this one down I found some bent push rods, the head had 4 seized intake valves due to what I think is oil that has worked it's way into the valve guides. The block on the other hand looks like it has been recently rebuilt (all new bearings, pistons, cam, etc...) So I think I can clean up and rebuild the head and she may fire right up.
If that all works out then I'll be able to figure out if the 904 I have is still operational and if it is then I am going to keep that setup until I complete all of the body work and interior at least. If for any reason the 904 is not operational, then I might just throw another 904 in it OR I might look into doing a 903 only because I prefer manual cars and I would like to do as little Fab as possible if I am keeping the slant six.
Now the final scenario is that the slant six does not come back to life for cheap, in which case we are definitely looking at a V8 swap.
Basically If the slant six runs I want to stay as close to bolt on as possible and if it doesn't then we turn her into a true 8 cylinder beast.
Again I appreciate all the feedback as I do not yet know which of those scenarios is going to play out. I put some pics of the head below as well so you can see what I was talking about.
