68 Dart dash removal
68dart68
Member
With the winshield removed, what's the procedure (easiest or otherwise) to remove the dash for restoration? Any tips would be appreciated or if there is a website to go to.
Drop or remove the column. There is a bolt on the lower corner on each side. Then there are 5 or 6 bolts under the rubber where the windshield was. Don't forget to unhook the wiring from the firewall.
