Hobbestheman
Active Member
I need some help from FABO members with direct knowledge and experience with steering column modifications. I have a 68 Dart with auto transmission, power steering and the shifter on the column. I want to swap to a console with floor shifter.
If there is a instruction manual or website that answers these question then please direct me there and ignore the following questions.
Can I swap the shifter collar with a collar from another column that doesn't have the shifter lever boss and gear indicator, or would I have to modify the existing collar? What other shift linkage parts will I need to remove, reuse?
Than you for your help.
