chrisnben
MR Badfish
1968 Plymouth Barracuda Formula S Fastback
Up for sale is an original #s 383 4-speed (1 of 553). Nut & bolt rotisserie restoration. A street car with many subtle internal upgrades. She still maintains a stock appearance- giving it that stealthy attitude. Everything functions as it should.
gauges were calibrated by Redline in California, Legendary int., restored rallye steering wheel, new quarters & trunk returns, radiator support & inner fenders (had fenderwell headers BITD).
425 HP/ 450 Ft.Lbs. Contoured frame ties & Hemi torque boxes. The stock engine parts are boxed up, factory build sheet & fender tag included. Serious interests only. $36,900. PM me here for more details & pics. Located in Sun Prairie, WI
Engine-
original #s block .030 & zero decked 10/1 comp. ratio. Original #906 heads- CompCams springs (good to 625 lift), 10deg. Locks & retainers, stainless valves and hardened seats. Diamond forged flat-tops, Comp XE275HL (231/237@50 & .525 lift), Edelbrock D4B intake; aluminum water pump, BHJ balancer; 7qt. pan w/ Milodon pickup/windage tray; Schumacher Poly-lock mounts; Fel-Pro gaskets.
Transmission-
#s matching 4-speed & bell- new snychros and gaskets; upgraded Hurst shifter mated to stock early 68 Inland shifter; McLeod RST clutch & pp; 3 DOM steel driveshaft w/ 7690 joints
Exhaust system-
Mopar HP manifolds- A-body right side & B-body left side- much better flow over stock (that chokes out 40 hp). Relocated Z-bar to accommodate Accurate Exhaust 2-1/2 headpipes, turbo mufflers & TTI 2-1/2 tailpipes w/ stainless tips.
Suspension-
Front- Factory 383 torsion bars & sway bar; C-body 11/16 tie rods and sleeves.
Rear- Mopar XHD leaf springs w/ poly bushings; 8-3/4 housing narrowed slightly & widened wheel housings to fit larger wheel/tires. #489 case- rebuilt w/ 3.55 gears & Sure-grip unit; Dutchman racing axles w/ 3 studs. Wheel Vintiques 15x8 rear on 275/60/15 radials; 15x7 front on 215/65/15s
Ignition & Charging System-
Firecore Ignition wires- black w/ orange plug boots; MP recurved 383 electronic Distributor w/ correct tan cap; FBO Ignition module w/ built-in adjustable rev limiter; Pertronix Coil; FBO electronic VR; Mopar 78A alternator; Mopar mini starter; Mopar yellow-cap battery
Fuel System-
Edelbrock AVS 650 cfm carb, Edelbrock HP mech. fuel pump; New tank w-3/8 pickup & lines to carb; correct Mopar fuel filter
Brake System-
Mopar master cyl., steel lines, T/A prop. valve, 11 Dr.Diff front discs, B-body spindles; new B-body 10x2-1/2 rear drum brakes & hardware
Cooling system-
New Glen Ray correct 1968 Radiator #033 & date coded to the car; factory shroud, spacer & Mopar hoses w/corbin clamps; new heater core.
Engine-
Transmission-
Exhaust system-
Suspension-
Fuel System-
Brake System-
Cooling system-
![003_zpsa5lgcldg.jpg](http://i265.photobucket.com/albums/ii228/chrisnben_bucket/1968%20Formula%20S%20Barracuda%20383/003_zpsa5lgcldg.jpg)
![015_zpsrbzlsl6d.jpg](http://i265.photobucket.com/albums/ii228/chrisnben_bucket/1968%20Formula%20S%20Barracuda%20383/015_zpsrbzlsl6d.jpg)
