[FOR SALE] 68 formula s fastback 30k o.b.o
Derrick Kidwell
Levels wv
Rating - 0%
0   0   0
1968 Formula s fastback, fresh 512 build balanced and blue printed,440 source crank, eagle rods , Indy aluminum heads and intake, Harland sharp valve train, pro comp cam, auto transmission ,reverse manual valve body, 4:30 locker gears, cal Trac, racing adjustable shocks,caged, not tubed, new legendary front buckets,new tires and new windshield. Mallory ignition, originally 340 auto, no fender tag or build sheet, have many original parts if you want to go back but not the original engine or transmission. Driver quality paint. Hemi hood now. Has solid floor and rails , is stiffened, has small bubbling in rocker in front of rear tires. More pictures available. Located in Levels WV 25431
