Replaced pump, still does it.
Here is a list of everything replaced:
Carb
Filter
Pump
Coil
Spark plugs
Wires
Checked tank and sending unit
Voltage regulator
Ballast resistor
I can conclude fuel is not the issue. Could it be the magnetic pick up in the distributor or the ecu? The ecu was replaced a few years ago. 4 pin orange.
Carb
Filter
Pump
Coil
Spark plugs
Wires
Voltage regulator
Ballast resistor
