69 383 Dart value ??
Mopar General Discussions
  1. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    I'm thinking about buying a 69 Dart GTS 383, the car is a blasted shell in prime that needs a lot of metal work. it has doors,trunk lid, glass - windshield and som other misc parts. its a title, vin and build sheet non numbers match to the body .. any opinion on its value ??
  2. oldmopardude
    oldmopardude Well-Known Member
    852
    152
    Jan 31, 2011
    omaha nebraska
    Local Time:
    2:42 AM
    The VIN, and build don't match the body, or the drivetrain doesn't match the body?
  3. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    the vin and build doesn't match the body
  4. Oklacarcollecto
    Oklacarcollecto Life is an experiment
    17,292
    287
    Mar 13, 2009
    North Central Oklahoma
    Local Time:
    2:42 AM
    How many body numbers have you checked? If the title/vin doesn't match any of them the car is illegal and is nothing but a parts car if it isn't stolen.
  5. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    the core support matches, nothnig else
  6. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    I think someone scrapped the original car
  7. Oklacarcollecto
    17,292
    287
    Mar 13, 2009
    Local Time:
    2:42 AM
    Your making this as clear as mud and it is impossible to help you without detailed information.
    What about the other body numbers?
    Does the title match the vin plate that is on the dash?
    What numbers match what if any?
  8. Oklacarcollecto
    17,292
    287
    Mar 13, 2009
    Local Time:
    2:42 AM
    It is illegal to swap vin/title between cars.
  9. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    sorry, vin tag, title, build sheet and the number on the core all match. the number on the trunk rail does not match and I don't know where the rest of the numbers are
  10. 67cudafb
    67cudafb Well-Known Member
    1,908
    100
    Nov 21, 2011
    Florida
    Local Time:
    3:42 AM
    Sounds like it has been re bodied. I wouldn't touch it with a 10' pole. You will end up putting a lot of $$ in it and may not be able to sell it down the road. IMO
  11. dave72demon
    dave72demon Member
    18
    0
    Feb 22, 2014
    michigan
    Local Time:
    3:42 AM
    yeah, could be. do you know where the other vin #s are ?
  12. barbee6043
    barbee6043 barbee 6043 FABO Gold Member
    12,208
    4885
    Jul 20, 2008
    Shepherd, Texas ( SE Tx)
    Local Time:
    2:42 AM
    If i remember the other vin no. Is generally under truck seal area??? Can vary by model? People can change the rad support from the donor and rebody it as they say... To match the vin and papework... Parts car only to me..... If ya want a clone, start with legal car, built as a clone and if ya sell tell them it is a clone.... Saves a lot of a-- kickings???
    If ya want a real car the factory built, them pay the price for such a rare gem!@???? Just me...
  13. 68383GTS
    68383GTS Well-Known Member
    7,358
    848
    Nov 15, 2007
    East Peoria,IL
    Local Time:
    2:42 AM
    Find a different project.....
  14. 67valiant 100
    67valiant 100 go fast or go home
    1,663
    30
    May 3, 2010
    Orange County NY
    Local Time:
    3:42 AM
    could be a real car and someone swapped out the trunk area as a patch cause that is a common spot to rust... You need to inspect it further. You might get lucky and sand the primer away to see which vin # was added if they did a sloppy job welding it in.
  15. oldmopardude
    852
    152
    Jan 31, 2011
    omaha nebraska
    Local Time:
    2:42 AM
    look again, if it was rebodied, somebody went to the trouble of removing the radiator support. Look at the welds, most people are crappy welders, does it look original? there are two sets of numbers under the drip rail, drivers side, people sometimes mix them up, they can be close together. one is the car, another is a parts stamp that means nothing. my GTX has that as well as the vin, about six inches away.
    If the car has a sway bar, 10 inch brakes, 8 3/4, and a second hangar for dual exhaust, then somebody went to a lot of trouble to clone something, or it is a GTS. Look to see if the bracket for the right exhaust was tacked on, or properly bolted on.
    it takes some thorough examination to really be sure. Is the windshield and seal really old,(assuming it is in the car) The trunk lip number is the only other number that year. Does it look like someone replaced the whole Quarter? Look at the color ID on the build sheet. do you see that color anywhere inside, or left over and missed by bodywork? it can be difficult to be sure, but an experienced eye is what you need here. Match all the options you see on the car, and see if those codes are on the sheet.Buckets, floor shift, manual or power, A/C, etc. Vinyl top or no, the roof attachment to the Quarter will tell you. it is highly unlikely a thief would be able to secure a car identical in every way to switch. That build sheet has far more Info on it than a fender tag. Sorry for the long post! I hope that helps.
  16. Rocky_JS
    Rocky_JS 'cuda
    4,198
    154
    Feb 27, 2011
    Highland Maryland
    Local Time:
    12:42 AM
    I agree the reason they used two sets of numbers on the body is in case of an accident. I would do as suggested and inspect and verify the core support was not replaced and that the quarter panel was it should be a lot easy to see that the quarter had been replaced.
    Does it have any of the drivetrain? engine and trans should also have numbers on them. It should also have torque boxes in the rear at the very least.
    The fact that one number doesn't match is not that surprising. If it had been hit earlier in life when quarters were not being made it would be normal to cut one off a car to replace a damaged one. The numbers from the lip would have been an after thought as they were not that valuable then.
    As said verify the car against the build sheet. The color especially, traces should be found under the drip rail window seal, inside the quarters, inside against the firewall, if undercoated, scrape some off under the rocker panel. The color should match the factory color.
    • Like Like x 1
    • dave72demon
      dave72demon Member
      18
      0
      Feb 22, 2014
      michigan
      Local Time:
      3:42 AM
      very helpful info, thanks everyone !
