[WANTED] *69 A body stuff needed*
626notchback
Mopar Rookie
High Desert
Rating - 0%
0   0   0
OK, so I need some parts. All parts will be going on a 69 Barracuda
floor shift, steering wheel column bezel...or auto delete bezel
manual pedal assemble (clutch, brake, gas)
69 Barracuda front grill stuff
Front bumper brackets (all four)
Rear window molding gap sheet metal (pictures below)
PM sent. I have the bumper brackets but the sheet metal I have isn't as good as I thought.
I've got a gas pedal / throttle cable. I also have some grill stuff for a 69 that's in rough shape but it you have the time to work on it you'll save over buying new. Shoot me a pm.
do you need the pieces to convert your existing column to look like a floor shift? or are you looking for a whole column?
I also have 1/2 the stuff you need, but non in too great a shape, I have the grill surround, grill, and directional, parking lights. One busted column with good collars.
[ame]http://youtu.be/fpDb-whVwqw[/ame]
I have the sheet metal on a parts car it looks to very solid in the corners
with 1 pin hole on the right side down in the channel (easily repairable) and the center section between the quarter seams is perfect. If interested pm me and we will work something out
Cudascott
