[WANTED] 69 barracuda antenna
moparstud440
Keymar, MD
I'm in need of an antenna assembly for a 69 barracuda. I have one but the antenna is broken in the base and the wire is cut so all I have that is of use is the lock nut and bezel, I need everything else.
I just bought one from a pick n pull wrecking yard for $10 off a '76 Dodge p/u. Identical to my old one, which was from a '68 Barracuda.
