rod440
'69 Barracuda Spring special fastback,runs & drives,original engine & trans,have build sheet,clean Montanna title.Here is a list of parts that were replaced this fall...master cylinder,brake hoses,brake fluid,water pump,coolant hoses,fuel tank,pad & fuel sender,rubber fuel hoses,fuel & oil filters,rebuild carb,front wheel bearings & seals,battery ground cable,& other odds & ends.As you can see from the photos it has rust issues but is definitely a good car to restore.Car is located in Neenah,WI. Price is $3500.
