[SOLD] '69 Barracuda
rod440
Neenah,Wi
'69 Barracuda Spring special fastback,runs & drives,original engine & trans,have build sheet,clean Montanna title.Here is a list of parts that were replaced this fall...master cylinder,brake hoses,brake fluid,water pump,coolant hoses,fuel tank,pad & fuel sender,rubber fuel hoses,fuel & oil filters,rebuild carb,front wheel bearings & seals,battery ground cable,& other odds & ends.As you can see from the photos it has rust issues but is definitely a good car to restore.Car is located in Neenah,WI. Price is $3500.
More pictures please. Interior, left and right of engine, is the roof rust or vinyl?
Here are the photos that some of you asked for.The frame rail rot is on the driver's side front.The rest of the car underneath looks pretty nice,the trunk floor is nice,there is some minor rust on the driver side front floor,otherwise the floors look good.
The interior will need all new upolstery & carpet but everything is there for it.
Since I first posted this ad I have restored the heater box with a new heater core & seal kit from DMT , replaced the wiper pivot seals & gaskets , installed a new glove box liner , had the radiator cleaned , cleaned & detailed the dash cluster , replaced the dash pad & picked up more misc. parts. I will post some more recent photos this weekend. Thanks! Rod.
Here are some photos from yesterday. It now has nicer bumpers.I've also added a factory RH muffler hanger (kinda hard to find) for dual exhaust,and I have a good used windshield for it,also a pair of correct wiper blades. The car runs / shifts / drives & stops pretty much as it should & is pretty darned close to being a good driver. I am firm on the price $3500 (unless someone wants to pay me more!). Thanks for looking! Rod
It has been repainted below the stripe.Above the stripe appears to be original,whats left of it!
Still for sale,but with a new higher price.I replaced both engine mounts & transmission mount,purchased & fit (but not installed) U S Cartool frame connetors,Safe T Cap covers for the front frame rails,new lower door hinges & a pair of Cragar SS wheels with BFG T/A's in nice shape,also new lug nuts.New price is $4200 firm.
