69 cuda disc brake parts
Fisher
Old Guy with a Cool car.
Regina Sask Canada
I scored a complete front clip. now it looks like i am not able to buy brake parts here in Canada for this front end? Any idea where in the USA i can get new rotors and calipers for this deal? Small bolt pattern. what do i need to buy here?
You have the highly desired Kelsey-Hayes 4-piston calipers and rotors. Rebuilt calipers are $$$. Look on rockauto.com The rotors used to be expensive (~$90 ea), but are now ~$25 from Centric. The downside is if you ever want to switch to an aftermarket disk setup like SSB or Wilwood, those adapt to either a 9" or 10" drum spindle.
So Rock Auto is the only place in North america to get brake parts from? wow this is going to be a bit of a bear.
Rock was cheapest when I had my 72 Dart. Oreilly's has parts too. Advance also did. Autozone had the pads and the pads are the same as the mustangs with those brakes.
As it turns out i can special order the rotors from the USA, the calipers are not available, and have to be sent to Wagner to be rebuilt.
