71twister3bytheknee6
I need expertise...My pass. door is pretty much alligned,with good spacing,lines,etc.My striker post is fine,no metal fatigue around it,and it can be adjusted.My hinges have very little wear.The push down lock button locks as it should,with the key outside,or you inside with the door shut.The door opens and closes fine,but it can be pushed in another 1/8 inch past the proper in-out allignment of the rear part of the door.Needless to say this causes a major rattle over bumps.I thought it might be due to compressed,worn upper and lower black bumper stops on the door.I checked this out on my drivers door,removing the stops alltogether,and the door stayed put,not moving a fraction of an inch when pushed in.I could fix the rattle by putting oversized bumper stops on the door,but I wouldn't be fixing the problem.Is the latch mechanism that catches the striker post worn?I did lubricate the mechanism with white lithium aerosol grease.Any help would be greatly appreciated.The latch mechanism to me looks like a real puzzle/nightmare.
