69 Dart 340 A/C belt routing pictures
CL3406
BC
Hello . Does anyone have a 69 Swinger or Cuda with LA340, A/C & power steering they can take pictures of all the belt routing, proper pulleys, brackets ect? With the stock RV2 compressor still utilized. I need to see what I need to obtain to get mine back to stock. I can provide my cell number if easier to send pictures. Thank you.
I have a '72, parts would be similar, but not all. Guess this is 100% different than a '67, was going to delete it, but decided not to .
Good luck.
Ac brackets & pulleys for 68/69 are very difficult to find. I would advertise in a wanted ad on here and see what you can find.
I converted mine to a 70 & up belt system. What a mistake. EVERYTHING is different. Just a few things you would need to deal with or replace.
Compressor pulley
Alternator pulley
Water pump
Water pump pulley
Radiator
Hoses
Bypass hose size
Hidden timing marks
Power steering brackets (low mount ps pump conflicts with motor mount stand on a 69)
I would never do it again. But, on the plus side it is a very simple setup once installed.
If you can’t find the original parts, I would go with an aftermarket setup like a sanden and aftermarket brackets.
