69 dart auto center console linkage "lower rod"
motobro
california
69 dart here, going from column shift to console floor shift auto.
Using a 727 torqueflight.
I picked up a center console, shifter (with no button) and console brackets.
I see that year one and classic both sell A/T shift lever kits, but they don't include a "Lower rod" dodge part # 295DZ12.
Does anyone know where to get one of these ?
Are there any repops out there ?
What other year cars, trucks, vans etc. share the same part ?
thanks in advance !!!
Wish I had a dollar for every time someone here needed that linkage rod, the tail shaft mounted bracket, or both.
Best I can figure, guys pull what they can from inside parts donors but leave what's under the donor behind.
Good hunting
I believe that lower rod is the same for console shifted A-Bodies from 67-76.
Put an ad in the "Cars & Car Parts Wanted" forum here on FABO
Mid 68 through 76 A-Body with a console used the same rod. The only one truck or car that is really close and many times mistaken for an a-Body is the 69-70 B-Body console rod which is very hard to find as well. I have the correct rod but it is with a complete set up i have for sale.
Thank you for the clarification of mid 68 thru 76. Always learning.....8)
No problem i learn something new myself almost every day.
The A-Body 67 to mid 68 part number is 2781418 and the mid 68-76 number is 2950212 The 69-70 B-Body part number is 2950211
