rm69dart
ok i have the 73-74 spindles and upper control arms. but i want to replace pitman arm, idler arm, lower ball joints. so what year should i buy all the new parts 69 or 73-74?
Lower ball joints have to be for 73-74 Pitman arm and idler arm can be for the 69ok i have the 73-74 spindles and upper control arms. but i want to replace pitman arm, idler arm, lower ball joints. so what year should i buy all the new parts 69 or 73-74?
what about the tie rod ends what year do i get them. my dart is a 69 putting on 73-74 disc
Need help guys !!
I converted my 9" ft / bk to disc my car is a 68 Ply Val olk I found a donor car not to sure of the year it was a Duster disc brk 4.5 bbp just what I wanted so I bought complete brakes ,rotors spindles etc. However I found out it takes a lager upper ball joint ( I didn't get the A arms or the portion valve either so what are my options donor car is gone ! Thanks ray
