69 dart brake drum to disc
rm69dart
Costa Mesa, Calif.
ok i have the 73-74 spindles and upper control arms. but i want to replace pitman arm, idler arm, lower ball joints. so what year should i buy all the new parts 69 or 73-74?
Lower ball joints have to be for 73-74 Pitman arm and idler arm can be for the 69
Ball joints are Moog K781 & 783 (73-76 A body) or compatible.
Pitman and idler are for the year/style of the centerlink.
Top one is 67-72, bottom is 73-76. Note how the tie rods attach compared to the pitman/idler.
Need help guys !!
I converted my 9" ft / bk to disc my car is a 68 Ply Val olk I found a donor car not to sure of the year it was a Duster disc brk 4.5 bbp just what I wanted so I bought complete brakes ,rotors spindles etc. However I found out it takes a lager upper ball joint ( I didn't get the A arms or the portion valve either so what are my options donor car is gone ! Thanks ray
Need help guys !!
well, you can look for the large bolt upper control arms from any '73-76 year A-body that had disc brakes...sometimes they show up on this site for sale...you could post a wanted add on the site...the aftermarket (reilly motorsports, mancini racing, firm feel, magnum force, pst, just suspension, hotchkis) also makes tubular upper control arms with the larger ball joint, more expensive though, expect to pay around 3 hundred bucks for those ones..there is also an outfit making new reproductions of the large ball joint A-body arms on ebay, but I'm not sure how good those are, i have no experience with those..
