69 dart column shift linkage rod
Mple ridge
Good morning,
I am a new member here and I am looking for the rod that connects the column shift and the transmission.
The rod ends are 90 degrees to each other.
Thanks,
Zach
Welcome to FABO! There is a series of linkage that runs from the column to the transmission. A couple of rods, a couple of brackets, a bell crank, several clips, etc. Any photos of what you have or what you need? What engine/trans combo do you have?
I have a 408 stroker mated to a Coan 727.
I will post pictures but on the side of the tranny there are two levers one with a ball end for the kickdown and one with a hole in it that connects to your column shift via a 1/4 inch rod which is what I need.
Thanks for your time.
Zach
