69 Dart fender tag
jefflock
69 Dart 408 10.08 best pass so far
Kansas
Can anyone tell which line and numbers refer to the brake system on the fender tag? I have a parts car that has had all the front brake stuff removed. It still has the proportioning valve on it and I need one for a disc brake system. I'm hoping this will be the right one. Is there another way to tell which is which? Thanks Jeff
More than likely if it is a 69 Dart it ISN'T a Disc Brake Car...The only way it would be is if it was a Big Block,340(some) Or Special Order.....
Is the Master Cylinder still on it?If it is and has a Large and Small Reservoir then it is most likely a Disc Set-up..Was it Power Brake Car?This is another way to tell.
Alot of times the Brakes are not all on the Fender Tag.I Believe if it is on the Tag it is on the Second Line From the Bottom Towards the Left.
SS
It was a 340 GTS car. Nothing remains of the brake system except the proportioning valve and some of the lines. I was reading in the Fine Lines catalog and they stated that there should be another valve in the line going to the rear under the drivers feet. It isn't there so I'm guessing that it is a drum car.
I think disc brakes are standard with a trailer hitch. not totally positive though.
I just checked my 69 dart facts and features manual and I found that disc brakes were only an option and availible on all models. the sales code is ( B41 ). I still don't know if thats on the fender tag. but would be on the build sheet
