Vin/Fender Tag Help
NSdartSW
Southern California
I’m just trying to find more information about my car(‘66 Dart Wagon). I’ve looked at a few different sources for decoding both the VIN and the fender tag. Sometimes the info lines up with the know about the car and sometimes it doesn’t. For example, the manual form My Mopar says the fender tag indicates a 318 but the guy I bought the car from pulled the original 273 which it what other decoders tell me. I also might be reading it wrong but trying to find the production number for my car has been elusive to me so just looking for some help and extra eyes look at all the info to make sure I’m understanding it all as I am new to the Mopar family.
I appreciate all the help and info I’m sure I’ll get from y’all thank you.
VIN-LH45D65139060
D is 273 in the VIN, the 318 was not available in 1966 in a Dart. KK1 is one of my favorite colors, light turquoise! Anything else you want to know about your fender tag?
VIN-LH45D65139060
The 5th digit on the VIN is engine. D is 273
AB 31 on the fender tag is 273 2 barrel.
That’s what I thought but the manual threw me a little wrench, just the production number. I may be doing it wrong but I read it as 39xxx as it’s the last numbers of the VIN correct. But from what I can find online only about 30k darts were produced in 66.
Thank you for confirming my thoughts.
the VIN is 139060, they always start at 100001 there were 4,197 1966 Dart 270 6-passenger wagons built at all Chrysler plants in 1966. 897 automatics were built from the Los Angeles plant
And of those 1487 wagons, 934 had the 273-2 barrel and 879 of those were automatics. (my Galen book anyway) Cool car and not many made.
Oh dang thank you I didn’t realize I was trying to find those kinds of numbers but didn’t have much luck. Was going to ask where you got all this good info thank you I appreciate it. Definitely going to appreciate it a little more now.
Welcome to the money pit!
MyMopar.com get your cars or Plymouth Factory Service manual, also wiring diagrams, they are in the FSM but others might be easier to read
ClassicCarWiring.com great laminated full color wiring diagrams best 25.00 I have spent.
Chrysler Historical new contact info. Stellantis Historical, because you have a 66 you can get a copy of your IBM card, it takes a few months and many are really hard to read BUT I can help with that. It has codes that are not on your fender tag but not a complete build sheet either.
As for production numbers as in total number of wagons made for a particular year there are sources on the net that have numbers but some might be suspect.
Your fender tag has a SO number on it, that is the sequence number, IT IS NOT associated with the VIN except on the IBM card and on a build sheet. The SO and some other bits MAY (I don't know when they started doing this) be stamped on the body in the left trunk lip under the weather-strip. On a wagon it MIGHT be under the seal on the left in the rear hatch door opening. And it MIGHT be on the radiator core support under the radiator coolant sticker typically on the drivers side in front and to the passenger side of the battery.
The stamped body numbers MIGHT read like 6220112345
6 = 66
2 = assembly plant, Hamtramck, MI
201 is month and day 101 thru 930 are Jan 1 thru Sept 30, A01 thru C31 are October 1 thru December 31. cars with build dates before August are build in the year their model number is, Cars built from August thru Dec were built the year before their model year. So a 66 built on 915 would be a 66 model year built on Sep 15 1965 and a 66 model year built 115 would be a 66 model built on Jan 15 1966
12345 is the SO number off the Fender Tag
As for VIN, it will only be on the VIN tag WELDED to the door pillar. There will be 2 holes that look like pop rivets should have gone in them but they are just alignment holes for when they welded it on the pillar.
The FSM will have the codes and descriptions of what the VIN should look like
Have fun and don't get upset if a grouchy old man gives you a hard time here on FABO, there are lots of us and sometimes we forget our manners
Just hung up on power breaks it definitely isn’t power breaks right now.
Post some photos of your master cyl and area on the firewall.
if it has a double master cyl it has been retrofitted at some time 66 was the last single master
A LOT can happen to these cars in 59 years.
This is how she sits now, hopefully these are helpful
well it is up in the air about power brakes It may have been removed. I was hoping to see some traces of the power brake mounting brackets in the paint etc.
according to the decoder M1 is power Brakes
As for engine...
Look at the drivers side front of the engine right under the head
in this area
IF your engine is original to the car then the numbers should read like
B 273 12-01
B is the model year ( A = 65 B = 66 C = 67 etc)
273 is the displacement
12-01 (1965) is the Assembly date (your car was built on or around Feb 03 of 1966 and so the engine would have been built a little bit before that. a few days, to weeks, to a month or two) If the date is after your car was built then the engine is for sure NOT original to the car. If it says A or C or any other letter that to says the engine is not original to the car ( an exception is a car built in the first few weeks of a run MIGHT have slipped through with an engine stamped from the previous line. (left over parts)
The U 1 typically is a car that was ordered vs a car that was speculated by a dealer to be sold later. meaning it was basically special ordered by some one
No longer the 273 unfortunately. The person I bought it from swapped in a junkyard 318 b/c it was locked up I guess. I am in the process of finishing swapping a ‘72 J head 360
