dcam57
So I was wondering if the gauge should operate when the ignition switch is in the accessory position.
Yes.So I was wondering if the gauge should operate when the ignition switch is in the accessory position.
Thank YouYes.
I'm at a loss then. It's a new harness circuit board and gauges.Will it do any damage the way it is.NO they do not............operate in accessory. Read your wiring diagram. The feed for the cluster IVR comes off IGN1. IGN1 is "igntion run" and is ONLY hot in "run."
Temp and fuel, and if you have a Ralleye cluster, the oil gauge all operate at same time. So if you suspect one is not working, look for "the other"
We have confirmed by doing those test that there is a problem with the fuel sender. Will having power to them in accessory do any damage.Is this a factory replacement harness or "universal?"
All gauges except the ammeter follow a common circuit
The IGN1 (dark blue) feeds power to the IVR or "voltage limiter" which then feeds power to the 2 or three gauges depending on Ralleye or not.
Each gauge has a sender terminal which goes off to that sender, and to ground. "Handily" they all three share the same resistance scale, meaning "so much" sender resistance to ground gives you say, 1/2 scale on the meter
So if temp works and not fuel, or vice versa, start by pulling the sender wire off and grounding it. Turn the key to "run" and the gauge should waste no time in getting to full or hot
There are nuts on the meter studs which contact the PC board. My car had corrosion there. Loosen/ tighten/ loosen the nuts several times to scrub them clean, might even replace the "fake" nuts with real ones.
So it could be the sender, sender wire/ bulkhead connector (temp not fuel), the gauge studs/ nuts, and the gauge itself.
Yes the gas gauge does work in accessory mode. Mines been working that way for 48 years.NO they do not............operate in accessory. Read your wiring diagram. The feed for the cluster IVR comes off IGN1. IGN1 is "igntion run" and is ONLY hot in "run."
You're welcome and yes mine has ALWAYS worked in accessory mode.Thank You
If it did someone has changed something. The FACTORY wiring is fed off the J2 circuit, dark blue, which is "ignition."Yes the gas gauge does work in accessory mode. Mines been working that way for 48 years.
I'm not going to argue with you either. Nothing has changed with my FACTORY wiring, it's always been that way. Nuff said.If it did someone has changed something. The FACTORY wiring is fed off the J2 circuit, dark blue, which is "ignition."
I'm not going to argue with you. Look it up. It's right there in the wiring diagram.
Thank's everyone sorry for all the problems I causedI'm not going to argue with you either. Nothing has changed with my FACTORY wiring, it's always been that way. Nuff said.
It's all good. You haven't caused any problems for anyone. Good luck with your issue.Thank's everyone sorry for all the problems I caused
Thank's narrowed it down to the fuel senderIt's all good. You haven't caused any problems for anyone. Good luck with your issue.
