69 Dart Grill Question
koryliss
Zion Crossroads, VA
Found a 340 Swinger in a yard but the grill appears to be incorrect - note the "outside view" (1st pix) the extension by the headlight (same on both sides). The inside view is tough to see but the grill does not come close to the headlight . It does not look broken (just too short) but perhaps I am missing the obvious... any ideas?
Thank you,
Kory
the headlight was mounted incorrectly, and they cut the headlight bezel, and added sheet aluminum to the grill...LOL butcher job!
The headlight is too far outboard. Looks like the headlight bezel was trimmed to fit the modified headlight location. Is this car now yours or still in the yard? As mentioned by 375inStroke, are the fenders 'glass or steel? '67-'69 fenders should all be the same with only the grill and headlight bezels different from year to year.
375inStroke and ocdart,
Based on the "magnet test" you are right - fiberglass!
It is mone now .... engine matches... not sure if I am going to restore or sell. Need to decide...
Thanks!!!
Kory
