69 Dart GT emblems and decals
GT4spdragtop
New Member
New England
Hello all,
I just picked up a '69 Dart GT convertible and it has been restored. The people that did it didn't put on any decals or emblems, so I have a few questions.
I found reproduction tire, coolant, and jack decals, but no emissions decal. My car is suppose to have number 79 for the 273 4 speed, but the reproduction for the 273 is #78 which appears to be right for '68 273 cars. Does anyone have a picture of their #79 273 decal from 1969?
Is there any specific guidance for the precise locations for the placement of these decals? I know the line workers basically slapped them on, but maybe there's some accepted ideal positions? The jack instructions in particular appear in many different locations in pictures of cars I found online. Did different plants use different locations?
My hood and quarters have no holes drilled for the emblems. Is it a sin to grind off the pins and use 3M double sided tape? What are the arguments for/against double sided tape?
Thanks everybody.
here's a picture of the Dart GT emblems. Same as a 1970 Dart GT but in a slightly different rear quarter location. Repops available from Layson's Restorations, a vendor member on FABO...
@str12-340: Thanks for your reply. I ordered replacements from Year One only to find out that they are on back order. I called and they said that they should be in by the end of the year... we'll see. If they fail to come it I will look at Layson's, thanks.
@cudamark: Thanks. I thought about that possibility, but my '74 Charger emblems are of similar weight and construction and were stick-ons from the factory. I just have a hard time wanting to drill holes in very nicely finished panels, but if it's the right way to go... I also don't know how I will be able to properly locate the holes. On the hood it is easy because there are areas underneath for the speed nuts. but the quarters have no such thing. For now I am collecting opinions, so thanks for yours.
If you go with the stick on method and discover that the location is wrong you can always move em. I agree with having a hard time drilling holes in nicely finished panels, breeding ground for corrosion to start. Just my thoughts.
Good luck with your car.
Did anybody send you pictures of the 1969 emblem location? I know that it is significantly different than the 1970 location.
@str12-340: I haven't received anything other than what you see here in this thread. I would like a good picture of the #79 decal if anyone has one. I don't think there are too many 273 four speeds out there though, unless the automatic used the same #79, not sure. I'd also like information on the locations of the other decals like the jack instructions, coolant, and tire pressure. There's a lot of variation online which is why I ask. My car was built at the Hamtramck plant, so ideally someone with a car built there. Thank you.
Pins are accessible with the rear panel removed and the quarter window rolled up. Should be able to peek in there and see where they were filled.
As far as the jack instruction decal is concerned the procedure on the assembly line goes something like this.... line worker stood on the driver's side of the vehicle, with the decal in their right hand he or she ( political correctness) would just slap the decal on the underside of the trunk lid as the vehicle continued pass. With different workers of different arm lengths and heights weights etc there is no real perfect location. Remember it's just a sticker on the underside of a trunk lid. The line worker is probably installing one every few seconds or minutes along with other operations. Sorry to be the bearer of bad news but a dart in 1969 was just a car and a low level vehicle despite what there worth today. So just peel off the decal from the paper backing and slap it on. Wherever it lands is correct.
Good luck with your project.
