Awesome car, I too am jealous! I agree with the advice already posted about your alternator. My method of troubleshooting would be;
#1 - swap in a known good alternator or have yours tested
#2 - replace voltage reg with a kn own good, or quality new one
#3 - bulkhead connector - you should inspect and clean this regardless
Good luck with it.....if you want your money back out of it just let any one of us know, LOL
Yep. Let's throw parts and money at it until.........we get tired of throwing parts at it, and run out of money.
Well that is clear across the state and a 4 hour ride so I guess I won't be coming right over to help you out....Man, that car looks clean....For 2600?? Wow, did you have a mask on and holding a gun? Because you stole that....Amazing....that is easily a 10K car just the way it sits now....I'm in Greensburg.
You need to...........
Download a free factory manual, here
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
and more manuals and other stuff here
http://www.mymopar.com/index.php?pid=31
Read the manual, section 8 about alternators. We can step you through some simplified tests
PLEASE READ this article. You don't have to DO this mod, just read the article
http://www.madelectrical.com/electrical-tech.shtml
It does a couple of things for you. First, it points out the pitfalls and the whys of the wiring in these old girls Second, there's a simplified diagram on that page which shows a good overview of the major electrical distribution in these cars
THINGS to watch for. As I said, we can step you through
Can you post the part no and better yet a photo of the newest alternator you have? The rebuilders of late "play games." Here's the thing. THERE ARE three or four major "big splits" in the types of alternators that would fit and be made to work--------without mechanical alterations------on your car
They are............
1......First year up through 69 alternator which has a single field connection, and one grounded brush
2.....1970---73? so called "round back" with isolated field, that is, TWO insulated brushes.
3.....1969 /earlier CONVERTED to insulated brush by the cheap rebuilders
4......73? and later so called "square back" with isolated brushes.
Your car has the "early" style regulator that is one insulated brush holder. You can use the LATER alternators (1970/ later) by grounding either brush and hooking up to yours as per normal
The problems..........................
you might have inadvertently gotten an isolated field unit, either original or rebuilder converted, meaning one brush still needs to be grounded to work
you might have a defective rebuilt alternator, not uncommon
you might have yet another defective regulator, not uncommon with today's "Chineseo" junk
VERY FIRST THING TO TRY
First, buy yourself some tools if you do not have them. Buy a bag or two of Radio Shack test clip leads. Buy a digital multimeter. Everybody sells these nowadays, parts stores, Sears, Lowes, etc
But a 12V test lamp and a spark tester gap from the parts store.
Unhook the green field wire at the alternator. Hook a clip lead from the big alternator stud to the field terminal on the alternator. BE CAREFUL. That big stud is HOT and IS NOT FUSED.
In subdued light, you should see a small spark. Start the engine, bring up RPM. The ammeter should show charge, more as RPM comes up.
Post back with this result
Did that dart come from Ohio? Was the engine knocking when you bought it?
Since my last post I have taken the car for a short drive. Once it's warmed up and driving the ammeter shows a "normal" charge while driving and the rpm's are up. When it's at idol it shows a slight discharge. As soon as I turn on the lights or the heater blower it immediately goes to discharge and doesn't charge whether its at idol or driving at higher rpm. Could it just be that cheap China made voltage regulator?
Does it ever show a substantial charge? EG you start it up, so the battery has been "used" a bit, with nothing on, it should jump over to charge "someplace" and taper back to the middle as the battery comes up.
At this point it's hard to say.
1...Go back to the first. Take a jumper wire, and unhook the green field wire at the alternator. Hook from the alternator field over to the alternator output stud. Run it "carefully" that is don't get crazy with the throttle. The more RPM, the more it should charge. It might not 'keep up' that is, might not show a positive charge at low RPM, idle, but "just above" curb idle, IE "fast idle" it should keep up with heater and lights in the "positive zone."
If it does NOT, hook your voltmeter to the battery, run it with lights and heater, and gently bring up RPM. At a speed "about" low cruise, IE 30-35 in high gear simulated, read battery voltage and post back
Next, move your voltmeter over to the alternator output stud and do the same thing. Post that reading.
Finally, disconnect the jumper wire, and hook the green back up "normal," and take a reading under these same conditions at the battery.
I'm thinking............
Either the alternator is actually not outputting the full amount, meaning it's defective,
Or there's a real bad connection in the charging wire between the alternator stud, through the harness, and to the battery.
