69 Dart RH Side Mirror
The mounting areas are opposite directions of each other.
The first photo is a remote driver’s side.
The other photos are the pass side I have.
What they said ..
But...
There is a remote RH matching mirror that came on, ( and I don't know which car) B,C,or E body
The OP was asking about a NON-remote LH mirror to be used on the passenger side. I've seen it done if you position it right and crank the mirror way in.
I had a 70 Road Runner that had the plain jane non-remote mirror installed by someone. (Not me & it WAS a factory mirror) You could not adjust it enough to see down the side of the car so, it surely did NOT work on a B body. I don't think Chrysler ever made a plain jane mirror for the passenger side of any car.
Had it taped on and if I rotate it, looks like it’ll work. Picked it up at Carlisle on Friday.
You may be good to go then but, I know I could not get it to the proper angle to see down the side of my R.R., it just wouldn't pivot in that much.
As mentioned, it's a matter of positioning the mirror in the right spot before you drill the holes. You can fudge those holes just a little to give you more angle too.
I just did this with a VERY expensive mirror on my wagon, which is in super nice shape. I was nervous too but had a smart buddy help me double check the positioning. Then as menttioned above taped it off, used a spring loaded center punch to set the hole centers and started with a 1/16 bit. I used a slow drill speed to avoid the bit walking. After the pilot hole I took it out to full screw diameter, again slowly. It came out excellent, just take your time. Holes are tough to fix if you botch it up - ask me how I know...:steering:
